[GRASS-dev] Temporal framework: error when trying to register vector maps using register_map_object_list()
Sören Gebbert soerengebbert at googlemail.com
Fri Feb 17 12:19:33 PST 2017
Its a bug, i will try to fix it.
Best regards
Soeren
2017-02-17 3:48 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> On Thu, Feb 16, 2017 at 9:28 PM, Laurent C. <lrntct at gmail.com> wrote:
>> Hello all,
>> I'm trying to register a list of VectorDataset objects in a STVDS
>> using tgis.register.register_map_object_list().
>> The same function works fine when trying to register a list of
>> RasterDataset objects.
>> However, when using it with VectorDataset objects, I get the following error:
>>   File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line
>> 480, in register_map_object_list
>>     if map_layer.metadata.get_min() is None and \
>> AttributeError: 'VectorMetadata' object has no attribute 'get_min'
>> Do I do something wrong or should I fill up a Trac issue?
> I didn't investigate, but that looks like a bug to me, so yes, please
> create a ticket.
> Anna
>> Thanks for your help,
>> Laurent
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
