[GRASS-dev] g.region -a results in a (slightly) different resolution
Paulo van Breugel p.vanbreugel at gmail.com
Fri Jan 6 09:30:45 PST 2017
On Wed, Dec 28, 2016 at 4:21 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Dec 24, 2016 at 10:40 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
> > So depending on
> > the intended behaviour, perhaps the note should be changed to:
> > "By default the region resolution is aligned to match the region
> boundaries.
> > With the -a flag all four boundaries are adjusted to be even multiples of
> > the
> > resolution, aligning the region to the resolution supplied by the user
> > (res=xxx), or, if not supplied, to the current resolution"
> From this text change it is not obvious to me what to remove and what to
> keep.
> Please send a diff, thanks.
Sorry for late response, was away. It seems the discussion on this topic is
ongoing, so let's see how that concludes
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170106/4859aae0/attachment.html>
