[GRASS-dev] [GRASS GIS] #3242: Gui does not disply correctly and locks up when scrolling down to make alternative mapsets visible in d.vect and d.rast.
GRASS GIS trac at osgeo.org
Sun Jan 8 14:19:09 PST 2017
  Reporter:  ewcgrass  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  7.0.6
 Component:  wxGUI     |    Version:  7.2.0
Resolution:            |   Keywords:
       CPU:  x86-64    |   Platform:  Linux
Comment (by annakrat):
 Have you specifically tested TreeCtrl Popup widet in ComboCtrl.py? I just
 want to make sure, because there is multiple widgets in this demo. The
 errors in your output are unrelated to this widget. Markus, if you have
 similar configuration, can you confirm this? I still think it's something
 in wxwidgets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3242#comment:8>
