[GRASS-dev] v.external: ID confusion
Martin Landa landa.martin at gmail.com
Wed Jan 11 04:03:26 PST 2017
2017-01-11 12:54 GMT+01:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> When I try to connect to a remote server in GRASS 7.2.1svn with v.external, I get "database not found" error.
new issue? I cannot reproduce it. Can you provide any details?
> However, linking the table fails in 7.0 because the ID column is in mixed cases and column names are not quoted in the SQL generated by v.external.
> BTW. Is it necessary to sort the ID column? Does it make sense if UUIDs are used as primary keys?
Any reproducable example? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
