[GRASS-dev] i.superpixels.slic ( was: #3142 Implementing SLIC image segmentation)
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 23 00:22:22 PST 2017
Hi Rashad,
On 22/01/17 11:00, Rashad Kanavath wrote:
> I fixed all the points from last mail.
Wonderful !
It seems that you missed one point (see in the ticket #3142/#3247).
Thank you so much for this great job !
Moritz
> On Fri, Jan 6, 2017 at 9:28 AM, Markus Metz
> <markus.metz.giswork at gmail.com <mailto:markus.metz.giswork at gmail.com>>
> wrote:
>     On Tue, Dec 27, 2016 at 9:05 PM, Rashad Kanavath
>     <mohammedrashadkm at gmail.com <mailto:mohammedrashadkm at gmail.com>> wrote:
>         I had pushed a updated version of code:
>         Done:
>         1. input is a imagery group from i.group (handles all raster in
>         the group)
>         2. removed rgb2lab conversion
>         3. implementation of id output map
>         4. replaced  fmin with MIN and MAX macro
>         5. compactness is a new option to module? (default is 20 from paper)
>     Wonderful, thanks!
>         TODO:
>         1. add option for SLICO
>         2. use segment library to avoid memory limitation when reading
>         raster data
>         Hope this works now. Let me know If I missed something else.
>     Code clean-up:
>     - please use tools/grass_indent.sh
>     - move variable declarations to the beginning of a code block
>     - convert C++ style comments to C style comments
>     - line 155
>       int sz = nrows * ncols;
>     can cause integer overflow. Use off_t (large raster maps can only be
>     handled with LFS, i.e. off_t being a 64bit integer).
>     - fix L157: must be
>       int **pdata;
>       pdata = G_malloc(sizeof(int) * group_ref.nfiles);
>     - Lines 317,318 are correct, line 320 is wrong
>         And...
>         Happy New Year to all :-)
>     Happy new year to you too!
>     Markus M
>         On Thu, Dec 22, 2016 at 10:12 AM, Markus Neteler
>         <neteler at osgeo.org <mailto:neteler at osgeo.org>> wrote:
>             On Thu, Dec 22, 2016 at 12:01 AM, Markus Metz
>             <mailto:markus.metz.giswork at gmail.com>> wrote:
>             > Adding
>             > #undef MIN
>             > #define MIN(a,b) ((a) < (b) ? (a) : (b))
>             > as in other GRASS modules is a nice solution to keep things simple and
>             > portable.
>             ... how about a adding this and similar definitions to gis.h?
>             markusN
>             _______________________________________________
>             grass-dev mailing list
>             grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/grass-dev
>             <http://lists.osgeo.org/mailman/listinfo/grass-dev>
>         Regards,
>            Rashad
> Regards,
>    Rashad
