[GRASS-dev] vector layer contains error not detected by v.build nor cleaned in v.clean
Paulo van Breugel p.vanbreugel at gmail.com
Thu Jan 26 01:28:49 PST 2017
On 26-01-17 08:40, Markus Metz wrote:
> On Wed, Jan 25, 2017 at 5:19 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> > On 25-01-17 16:57, Markus Metz wrote:
> > On Wed, Jan 25, 2017 at 12:31 PM, Paulo van Breugel
> > > Dear all,
> > > I have a vector layer which I cleaned up using v.clean. It all
> appears to be fine, but when trying to export using the libkml in
> v.out.ogr and the type=area option, I am getting the warning and error
> messages like below:
> > > Warning 1: Ring Self-intersection at or near point
> > > 88.100626640406631 27.668444701473838
> > > ERROR 6: Invalid polygon
> > > In the resulting kml file, some of the polygons are missing. If I
> use the kml output in v.out.ogr, I am not getting any warnings, but
> similarly, some of the polygons are missing.
> > > When I import the layer in Spatialite and check the geometries I
> am getting similar warnings / error messages, e.g.,:
> > > 27 Ring Self-intersection at or near point 82.397900772562522
> 29.707213605319616
> > > How can I identify and clean these issues in GRASS? Checking for
> topological errors with v.build does not result in any error, and I
> tried the various tools in v.clean to no avail.
> > Did you try
> > v.clean -c type=boundary tool=rmsa,break,rmdangle threshold=0,0,-1
> > Yes, I tried
> > Also try v.build -e
> > Tried that too, it does not report any error.
> > Generally where the boundaries of two polygons with the same
> category touch each other by one point (illustrated below), Spatialite
> and QGIS (both using geos) seem to report an error for that point.
> > |  A  |+  A  +
> OK. In some cases, the vertex is not exactly on the line but just
> slightly off. It depends on how floating point precision is handled if
> this is regarded as an intersection or not. If GRASS assumes a smaller
> floating point precision error than GEOS, GRASS treats it as no
> intersection while GEOS might recognize an intersection. A solution
> could be to snap boundaries with a very small threshold.
That did help me to get rid of many of the reported errors, thanks!
> Just a guess.
> Markus M
> > I am not sure yet if that is what is causing the problem (missing
> polygons) when exporting to kml. I am cleaning a layer now for export.
> Will report how that worked out.
> > Markus M
> > > Paulo
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170126/ba094b53/attachment.html>
