[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1901 (master - c0c5512)
Travis CI
builds at travis-ci.org
Mon Jan 30 17:16:06 PST 2017
Build Update for GRASS-GIS/grass-ci
Build: #1901
Status: Still Failing
Duration: 1 hour, 26 minutes, and 18 seconds
Commit: c0c5512 (master)
Author: Václav Petráš
Message: wxGUI/toolboxes: store warning/error messages for later (see #3253)
GError and other message boxes during startup prevent
its completion unless OK is clicked quickly.
Messages are now stored and retrived later by the menu builder object.
lmgr stores them again and then shows them at the end of
init when everything is ready.
Messages (which are non-critical errors or warnings) are written as errors
to the Console output window. Console may flash during startup
but then Layers tab is shown anyway which seems like okay behavior
(careful user sees something happen but can ignore it).
Details of the exception are included into the message.
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70461 15284696-431f-4ddb-bdfa-cd5b030d7da7
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/d0ea3876d194...c0c55126d8ee
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/196781135
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170131/403b0a1b/attachment-0001.html>
