[GRASS-dev] [GRASS GIS] #3365: r.in.gdal: crash on large dataset
GRASS GIS trac at osgeo.org
Tue Jul 4 15:26:10 PDT 2017
  Reporter:  neteler  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.2.2
 Component:  Raster   |    Version:  svn-releasebranch72
Resolution:           |   Keywords:  r.in.gdal
       CPU:  x86-64   |   Platform:  Linux
Comment (by neteler):
 Replying to [comment:4 mmetz]:
 > Maybe you need to recompile GRASS with -g in order to replace "???" with
 some real information.
 My bad, I was calling the wrong grass72 version without debugging symbols
 in...
 > I could reproduce the problem, the segfault is caused by stack overflow
 because alloca allocates memory in the stack, while malloc and calloc
 allocate memory in the heap. I could fix the segfault by replacing
 G_alloca()/G_freea() with G_malloc()/G_free(). Please try the attached
 patch against lib/raster/.
 Thanks! r.in.gdal now runs, no more immediate crash. In some hours the
 dataset may be imported, I'll report.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3365#comment:5>
