[GRASS-dev] move everything from /lib/init/grass.py to /lib/python/init
Vaclav Petras wenzeslaus at gmail.com
Fri Jul 14 09:00:41 PDT 2017
Hi, Pietro. Just a short answer for now. This is exactly what I had in my
mind when doing the last major changes in the grass.py file. I generally
like the layout you suggested. It seems to me that choosing a good name for
the whole module will be a bit tricky. Also I think one reason for having
them there was that grass.py works without a he G Python lib found. Vaclav
On Jul 14, 2017 10:00 AM, "Pietro" <peter.zamb at gmail.com> wrote:
> Dear devs,
> What do you think if we move all the function that at the moment are
> contained in `/lib/init/grass.py` into a new subfolder under `/lib/python`
> The main advantages that I see are:
> - start a python script in GRASS just setting the the python path and then
> I can use the same functions that are defined for the normal GRASS start
> up, without duplicate code;
> - We can add unittest for the start up functions
> - We can remove code duplication between grass.init and grass.script.core
> What do you think?
> I did the changes and at least on my computer GRASS is working, all the
> changes are available at this link:
> https://git.osgeo.org/gogs/zarch/grass/commit/
> 27c8351423da645d938fb6c2e54781ee24e6f074
> I've split the functions that were contained in the grass.py in the
> following files, any comments?
> $ rg -e "^def\s[a-z_]+\(|^class\s[A-Z][a-z]*|^[A-Za-z_]+\s*="
> *gettext.py*
> 11:_ = gettext.gettext
> *message.py*
> 7:_DEBUG = None
> 10:def warning(text):
> 14:def fatal(msg):
> 19:def message(msg):
> 24:def is_debug():
> 41:def debug(msg):
> *utils.py*
> 13:def grep(pattern, lines):
> 23:def print_params():
> 62:def get_username():
> 85:def make_fontcap():
> 93:def ensure_db_connected(mapset):
> 102:def get_shell():
> *gui.py*
> 20:def read_gui(gisrc, default_gui):
> 53:def check_gui(expected_gui):
> 94:def save_gui(gisrc, grass_gui):
> 102:def gui_startup(grass_gui):
> 135:def start_gui(grass_gui):
> 148:def close_gui():
> 165:def clear_screen():
> 176:def show_banner():
> 188:def say_hello():
> 203:def show_info(shellname, grass_gui, default_gui):
> 229:def csh_startup(location, location_name, mapset, grass_env_file):
> 280:def bash_startup(location, location_name, grass_env_file):
> 313:PROMPT_COMMAND=grass_prompt\n""" % (_("2D and 3D raster MASKs
> present"),
> 338:def default_startup(location, location_name):
> 353:def done_message():
> *subprocess.py*
> 10:def call(cmd, **kwargs):
> *info.py*
> 5:BUILD_GISBASE = "@GISBASE@"
> 6:BUILD_PROJSHARE = "@CONFIG_PROJSHARE@"
> 7:CMD_NAME = "@START_UP@"
> 8:GRASS_VERSION = "@GRASS_VERSION_NUMBER@"
> 9:LD_LIBRARY_PATH = '@LD_LIBRARY_PATH_VAR@'
> 12:GISBASE = os.path.normpath(os.environ.get("GISBASE", BUILD_GISBASE))
> 13:GRASS_PROJSHARE = os.environ.get("GRASS_PROJSHARE", BUILD_PROJSHARE)
> *data.py*
> 13:def create_location(gisdbase, location, geostring):
> 47:def is_mapset_valid(full_mapset):
> 56:def is_location_valid(gisdbase, location):
> 72:def get_mapset_invalid_reason(gisdbase, location, mapset):
> 106:def set_mapset(gisrc, arg, geofile=None, create_new=False):
> 191:def set_mapset_interactive(grass_gui):
> 218:def lock_mapset(mapset_path, force_gislock_removal, user, grass_gui):
> 270:class MapsetSettings(object):
> 301:def load_gisrc(gisrc, gisrcrc):
> *clean.py*
> 8:def try_remove(path):
> 15:def try_rmdir(path):
> 22:def cleanup_dir(path):
> 33:class Cleaner(object):  # pylint: disable=R0903
> *env.py*
> 22:def path_prepend(directory, var):
> 31:def path_append(directory, var):
> 40:def set_paths(grass_config_dir):
> 97:def set_defaults():
> 126:def set_display_defaults():
> 134:def set_browser():
> 173:def ensure_home():
> 180:def clean_env(gisrc):
> 192:def load_env(grass_env_file):
> 218:def set_language(grass_config_dir):
> *compatibility.py*
> 5:ENCODING = locale.getdefaultlocale()[1]
> 11:def to_text_string(obj, encoding=ENCODING):
> *path.py*
> 11:_WXPYTHON_BASE = None
> 14:def readfile(path):
> 21:def writefile(path, s):
> 27:def gpath(*args):
> 35:def wxpath(*args):
> 50:def get_grass_config_dir():
> 78:def create_tmp(user, gis_lock):
> 125:def clean_temp():
> 132:def get_gisrc_from_config_dir(grass_config_dir, batch_job):
> 143:def get_grass_env_file(sh, grass_config_dir):
> 160:def find_exe(pgm):
> *system.py*
> 4:windows = sys.platform == 'win32'
> 5:cygwin = "cygwin" in sys.platform
> 6:macosx = "darwin" in sys.platform
> *gisrc.py*
> 13:def create_gisrc(tmpdir, gisrcrc):
> 33:def read_gisrc(filename):
> 54:def read_env_file(path):
> 64:def write_gisrc(kv, filename):
> 71:def create_initial_gisrc(filename):
> *batch.py*
> 9:def get_batch_job_from_env_variable():
> 32:def run_batch_job(batch_job):
> *parser.py*
> 29:help_text = r"""GRASS GIS $VERSION_NUMBER
> 114:def help_message(default_gui):
> 121:class Parameters(object):
> 135:def parse_cmdline(argv, default_gui):
> 183:def main(argv):
> I wish you all a nice week-end.
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170714/2ca1f041/attachment-0001.html>
