[GRASS-dev] GRASS Mac compiling - cairo problems
Michael Barton Michael.Barton at asu.edu
Wed Jul 26 19:40:54 PDT 2017
I solved it. I typo in the configure string. Thanks.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 26, 2017, at 6:26 PM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Wed, Jul 26, 2017 at 7:10 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
But fontconfig.h is IN the directory I've pointed to in the --with-cairo-includes= statement.
Here is my configure script:
./configure --with-macosx-sdk=/Developer/SDKs/MacOSX10.8.sdk --with-freetype --with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include/ --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-gdal-libs=/Library/Frameworks/GDAL.framework/Libraries --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes=/Library/Frameworks/cairo.framework/Headers/ --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-sqlite
Finished compilation: Wed Jul 26 17:02:45 MDT 2017
make: *** [default] Error 1
CMB-MacBook-Pro:releasebranch_7_2 cmbarton$ cd /Users/cmbarton/grass_source/releasebranch_7_2/lib/cairodriver
CMB-MacBook-Pro:cairodriver cmbarton$ make
gcc  -g -O2   -arch i386 -isysroot /Developer/SDKs/MacOSX10.8.sdk -fno-common  -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include   -I../driver -I/Library/Frameworks/cairo.framework/Headers/ -I/Library/Frameworks/FreeType.framework/unix/include/ -DPACKAGE=\""grasslibs"\"   -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -I/Users/cmbarton/grass_source/releasebranch_7_2/dist.x86_64-apple-darwin16.7.0/include -DRELDIR=\"lib/cairodriver\" -o OBJ.x86_64-apple-darwin16.7.0/text.o -c text.c
text.c:20:10: fatal error: 'fontconfig/fontconfig.h' file not found
#include <fontconfig/fontconfig.h>
1 error generated.
make: *** [OBJ.x86_64-apple-darwin16.7.0/text.o] Error 1
Hi Michael,
As far as I understand, compiler simply looks at all directories specified by -I (which are configured by ./configure) and pastes the -I path and the path in #include together and tests if the file exists. So I would first double check:
ls /Library/Frameworks/cairo.framework/Headers/
ls /Library/Frameworks/cairo.framework/Headers/fontconfig/fontconfig.h
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170727/22089fd3/attachment-0001.html>
