[GRASS-dev] GRASS flyer for the new osgeo branding
Luca Delucchi lucadeluge at gmail.com
Fri Jul 28 05:08:54 PDT 2017
On 27 July 2017 at 18:47, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Hi Luca,
Hi Jeff
> Some feedback from me:
> - remove "a" from the first sentence:   GRASS GIS is free and open source
> software for performing spatial analysis.
> - add an "s" to "consist" in the second sentence:  It consists of more than
> 450 modules
both done
> - in the third sentence, the term "map web services" confuses me, did you
> mean "web map services" instead??
yes, solved
> - in the next sentence, change "but still at the bleeding edge" to "but is
done, maybe should be "but it is still at the bleeding edge" ?
> - in the section "A long term endeavor":
>    - change "wide contributors community. Both combine" to "wide
> contributors community; both combine"
done
> - in the section "Interfaces":
>    - change "the simpler for new user" to "the simplest for the new user"
>    - change "text based" to "text-based"
done
Thanks a lot for the review
> -jeff
ciao
Luca
www.lucadelu.org
