[GRASS-dev] New attempt to update GRASS for Mac
Vaclav Petras wenzeslaus at gmail.com
Fri Jul 28 06:56:02 PDT 2017
On Thu, Jul 27, 2017 at 11:52 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> The other issue I'm hitting is that the configure argument to enable
wxPython, '-with-wxwidgets=' expects a path to a wx_config file. AFAICT,
wxPython 4 does not have such a file. And I can't yet find anything that
seems to serve the same function. I can put in a path to the
folder/directory where the wxPython 4 files live. While this compiles
without error, I don't think it is using wxPython 4.
--with-wxwidgets= is for wxWidgets (C++ library), not wxPython (its Python
wrapper), so you don't need to use at all. wxPython must be part of the
Python installation you are using.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170728/be907bf8/attachment.html>
