[GRASS-dev] [GRASS GIS] #3359: Missing/incorrect flag in i.superpixels.slic example
GRASS GIS trac at osgeo.org
Tue Jun 13 00:01:05 PDT 2017
  Reporter:  jpduffy      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [ticket:3359 jpduffy]:
 > Hello,
 > This help page -
 https://grass.osgeo.org/grass72/manuals/addons/i.superpixels.slic.html has
 an example which shows the following:
 > `i.superpixels.slic group=lsat output=segments k=2000`
 > `k` is not defined as a flag or a parameter anywhere. I think it should
 be updated to reflect the correct syntax.
 My fault: I had changed the parameter name elsewhere in the manual, but
 forgot the example. Done in r71181.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3359#comment:1>
