[GRASS-dev] [GRASS GIS] #3331: ctypes: ValueError: invalid literal for int() with base 8: '08420217248550443400745280086994171'
GRASS GIS trac at osgeo.org
Sun Jun 25 01:24:55 PDT 2017
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  Python       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  ctypes, python
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by hellik):
 Replying to [comment:43 neteler]:
 > Replying to [comment:37 hellik]:
 > > windows builds are broken in grass_trunk/lib/python/ctypes
 [https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71204-275/error.log
 error log]
 > After the float1.diff revert from yesterday also the Windows binaries
 are compiled again (see log in
 https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71214-276/)
 > Please install the latest binary and check if the digitizer works ok,
 thanks.
 tested with
 System Info
 GRASS version: 7.3.svn
 GRASS SVN revision: r71214
 Build date: 2017-06-24
 Build platform: x86_64-w64-mingw32
 GDAL: 2.2.0
 PROJ.4: 4.9.3
 GEOS: 3.5.0
 SQLite: 3.17.0
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-8-6.2.9200 (OSGeo4W)
 Editing of vector map <testdigi at user1> successfully finished
 Building topology for vector map <testdigi at user1>...
 Registering primitives...
 4 primitives registered
 17 vertices registered
 Building areas...
 One area built
 One isle built
 Attaching islands...
 Attaching centroids...
 Number of nodes: 3
 Number of primitives: 4
 Number of points: 1
 Number of lines: 1
 Number of boundaries: 1
 Number of centroids: 1
 Number of areas: 1
 Number of isles: 1
 confirmed, it works again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3331#comment:44>
