[GRASS-dev] Managing the translations with Transifex
Luca Delucchi lucadeluge at gmail.com
Tue Jun 27 06:03:50 PDT 2017
On 27 June 2017 at 13:01, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> Does transifex allow comparison and merge between projects ? I.e. would it
> be possible to create a relbranch72 project that imports from trunk, except
> for those strings that are different between the two ?
I don't think is able to do this.
We should also avoid to create to many projects on transifex
> It does, somewhat, thank you !
> How does QGIS handle this issue ?
Werner Macho is the person doing the job, I can ask him
> And is the integration between github and transifex easier than between svn
> and transifex ? That would make the case for migration even stronger.
I don't think so...
> One thing I take from this is that once this is ready, we should make a big
> call for translation, announcing the possibility to use transifex and very
> easily translate a few messages online.
+1, already some people is using Trnasifex since some months....
> Moritz
ciao
Luca
www.lucadelu.org
