[GRASS-dev] [GRASS GIS] #3311: Mismatch between CLI and GUI for r.colors using external rules file
GRASS GIS trac at osgeo.org
Wed Mar 8 04:39:39 PST 2017
  Reporter:  madi         |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.colors
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by hellik):
 Replying to [ticket:3311 madi]:
 > There is a mismatch between the command line and the GUI of r.colors
 when providing an external file for color rules. Via command line the
 correct (working) command is:
 > r.colors map=map_name rules=rules.file
 > but via GUI, browsing the rules.file, it will build the following
 command:
 > r.colors map=map_name file=rules.file
 here with the GUI the command expands to:
 r.colors map=myslope at user1 rules=D:\temp\test_c_rule.file
 it works
 tested with
 System Info
 GRASS version: 7.3.svn
 GRASS SVN revision: r70733M
 Build date: 2017-03-07
 Build platform: x86_64-w64-mingw32
 GDAL: 2.1.2
 PROJ.4: 4.9.3
 GEOS: 3.5.0
 SQLite: 3.14.1
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-8-6.2.9200 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3311#comment:1>
