[GRASS-dev] custom CRS
Benjamin Ducke benducke at fastmail.fm
Sun Mar 19 04:27:23 PDT 2017
On 18/03/17 12:15, Paulo van Breugel wrote:
> On 18-03-17 10:06, Paulo van Breugel wrote:
>> Dear all,
>> I have a shapefile which is in CRS ESRI:37203 [1], which is defined in
>> the prj file as
>> GEOGCS["GCS_Everest_India_Nepal",DATUM["D_Everest_India_Nepal",SPHEROID["Everest_Definition_1962",6377301.243,300.8017255]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
[SNIP]
>> +proj=longlat +a=6377301.243 +b=6356100.2284
>> +towgs84=295,736,257,0,0,0,0 +no_defs
Are you sure that your "+towgs84" parameters are correct?
It seems to me that you intend to apply a three parameter
transformation, but you are specifying a seven parameter
transform with the scaling (last parameter) set to "0",
which might have unintended consequences.
To specify a three parameter datum transform:
If you really want to specify all seven parameters, but
want only the first three to take effect:
+towgs84=295,736,257,0,0,0,1
Best,
Ben
>> Question 2: In QGIS it is possible to define a custom CRS using the
>> above. Can I do this in GRASS as well, and if so, how? Or can / should
>> I add this to the datum information files in $GISBASE/etc/proj/ogr_csv?
>> Regards,
>> Paulo
>> [1] https://epsg.io/37203
>> [2]
>> https://disqus.com/home/discussion/qgistutorials/georeferencing_topo_sheets_and_scanned_maps/#comment-1426454689
> A link that provides further relevant information
> https://github.com/klokantech/epsg.io/issues/49
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
