[GRASS-dev] r.binning
Markus Metz markus.metz.giswork at gmail.com
Tue May 2 23:25:21 PDT 2017
On Tue, May 2, 2017 at 3:45 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, May 2, 2017 at 5:31 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
>> Just had a look at r.binning, very useful.
> Thanks. But is is not complete yet.
The module name r.binning is rather non-descriptive. I would suggest
r.vect.stats because it can be regarded as the inverse of v.rast.stats, and
because it is similar to r.resamp.stats. All do statistical aggregation.
Markus M
>> There is a small error in the code, you are importing grass.script as
gs, so on line 33 it should be
>> options, flags = gs.parser()
>> instead of
>> options, flags = grass.parser()
> Thanks. Fixed.
> https://trac.osgeo.org/grass/changeset/70998
>> I could have made the correction, but I am not sure what is customary in
case of these kind of 'typos'.
> Good question. If it looks like the person is working on it, it is little
safer to just tell then fix, I think. Actually, I'll send you similar email
later today.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170503/f84e18db/attachment.html>
