[GRASS-dev] r.binning
Vaclav Petras wenzeslaus at gmail.com
Thu May 4 19:51:03 PDT 2017
On Wed, May 3, 2017 at 6:57 AM, Markus Neteler <neteler at osgeo.org> wrote:
> > The module name r.binning is rather non-descriptive. I would suggest
> > r.vect.stats because it can be regarded as the inverse of v.rast.stats,
> and
> > because it is similar to r.resamp.stats. All do statistical aggregation.
> +1  r.vect.stats sounds more descriptive.
Done in r71021. Thanks for the feedback.
https://trac.osgeo.org/grass/changeset/71021
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170504/fad9a58e/attachment.html>
