[GRASS-dev] Broken: GRASS-GIS/grass-ci#2145 (master - d37fa7c)
Vaclav Petras wenzeslaus at gmail.com
Mon May 8 14:28:33 PDT 2017
On Sun, May 7, 2017 at 8:00 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On May 7, 2017 12:36 AM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> > On Fri, May 5, 2017 at 6:36 AM, Travis CI <builds at travis-ci.org> wrote:
> > > GRASS-GIS / grass-ci (master)
> > > Build #2145 was broken.
> > > git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71024
15284696-431f-4ddb-bdfa-cd5b030d7da7
> > > We have updated our sudo-enabled Precise images! Read our blog post
for more details. Thank you!
> > There is some issue with packages in the Travis build:
> > The Travis build is based on Ubuntu 12.04 Precise and uses
ppa:ubuntugis/ubuntugis-unstable which seems to support 12.04.
> Is there a way to update to a more recent Ubuntu version?
It is mostly Travis-CI who decides what is running there, but they now have
Ubuntu 14.04 Trusty as a beta [1]. I've tried that since we had nothing to
loose and it seems to work now:
> Build #2153 was fixed.
> 6 minutes and 23 seconds
> Václav Petráš da79a7f Changeset →
>   travis: atempt to fix repo error using trusty beta environment
> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71066
[1] https://docs.travis-ci.com/user/trusty-ci-environment
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170508/54f413c9/attachment-0001.html>
