[GRASS-dev] [GRASS-SVN] r71093 - grass/trunk/vector/v.in.ogr
Moritz Lennert
mlennert at club.worldonline.be
Wed May 17 08:23:23 PDT 2017
On 17/05/17 15:18, Markus Metz wrote:
> On Wed, May 17, 2017 at 3:09 PM, Martin Landa <landa.martin at gmail.com
> <mailto:landa.martin at gmail.com>> wrote:
>> Hi,
>> 2017-05-17 15:00 GMT+02:00 <svn_grass at osgeo.org
> <mailto:svn_grass at osgeo.org>>:
>> > + /* TODO: remove below code, or use it in e.g. a new v.in.pg
> <http://v.in.pg> */
>> -1
>> v.in.ogr should work for all datasources. Special care should be done
>> for database sources.
It does, in the version that Markus committed. It did not work for me in
the previous version.
>> Connection string can be provided as fully
>> qualified. But also stored connections (via db.login) should be also
>> taken into account. Martin
That is something else, i.e. do we want to create more convenience.
> db.login is used for database access where GRASS reads/writes attribute
> tables, right?
> Why should these settings be used for OGR input? With v.in.ogr, OGR
> input can be anything, and OGR input has nothing to do with where GRASS
> creates a new attribute table. It is not clear why OGR should take into
> account GRASS db settings. Obviously this only causes confusion.
I agree with Markus here. db.connect/db.login settings should IMHO not
be (ab)used for read access to DBs.
I would, therefore, plead for a separate approach as already mentioned
(either db specific as in v.in.postgis, or generic in a v.in.db (I know
this name is already taken by an existing module with different
functionality) which might make it easier to define database connections
and possible allow the storage of connection parameters.
Currently, selecting "Database" in the import wizard also only works for
database that are on localhost. It would be great if information such as
host, database, login, and password could be passed to the wizard. Maybe
a specific v.in.db type module could help with that ?
Moritz
