[GRASS-dev] [GRASS GIS] #517: v.net.iso / v.net.alloc: keep original cat values or change output to field in attribute table instead of new map
GRASS GIS trac at osgeo.org
Mon May 22 02:42:51 PDT 2017
  Reporter:  effilc36     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  minor        |  Milestone:  7.4.0
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.net.iso
       CPU:  All          |   Platform:  All
Comment (by mlennert):
 Replying to [comment:9 mmetz]:
 > Replying to [comment:8 mlennert]:
 > > Pinging this after a class where many students thought they did
 something wrong because the approach using cat values is not very
 intuitive and is not directly visible.
 > > I still think that giving the option to write the results as new
 columns in the attribute file of the network would be a nice feature to
 have.
 > v.net.iso and v.net.alloc split some of the input lines: if the start
 node and the end node of a line belong to different classes, that line is
 split proportional to the cost difference and the two (or more) new lines
 will belong to different classes.
 > Therefore it is not possible to simply add a new attribute to input
 lines.
 Now that you say it, it's obvious... ;-)
 > What could be done is to add a new flag that 1) creates unique
 categories and adds an attribute table with class id (iso zone) and
 distance, 2) copies original arc attributes to a separate layer with some
 lines sharing the original arc category.
 That sounds like a good idea.
 And any objection to applying in any case a default color table ? I know
 (think) this would be a first, but for these modules one has to already
 understand GRASS' category vs attributes logic in order to understand the
 results. Coloring them by default would make the user experience easier,
 IMHO. Or at least give this option a an additional flag ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/517#comment:10>
