[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Martin Landa landa.martin at gmail.com
Tue May 23 08:21:00 PDT 2017
2017-05-23 17:12 GMT+02:00 Paul Schrum <paul.schrum at gmail.com>:
> In following the directions to build grass7_trunk, I put the source under
> /usr/local/src/grass7_trunk, and now everything I do which modifies anything
> must be preceeded with sudo.  I would like to eliminate this requirement for
> day-to-day work.
chown [1], chmod [2]. Martin
[1] http://www.linfo.org/chown.html
[2] http://man.cat-v.org/plan_9/1/chmod
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
