[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Helmut Kudrnovsky hellik at web.de
Thu May 25 00:58:04 PDT 2017
Paul Schrum wrote
> Going by
> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS and
> focusing on GRASS GIS 7 trunk:
> 1. Last week I did
> svn co https://svn.osgeo.org/grass/grass/trunk grass7_trunk
> On a directory under my ownership.
> 2.  Today in that same directory I ran
> svn up
> 3. I ran the large statement which begins with
> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
> Here is where the problem is.  It seems to go into an infinite loop.*
> Also note that when I run it from /usr/local/src/grass7_trunk -- where I
> was running it when I started this thread -- it succeeded.  It did not go
> into the infinite loop.
> * When the process starts, the first few lines read:
> ./configure: 229: ./configure: Cannot fork
> ./configure: 300: ./configure: Cannot fork
> There is a lot more I could send but have not, including the last lines
> before it restarts at the top of the loop.
> Please let me know what more information to five you or what changes I
> should make.
> - Paul
> On Tue, May 23, 2017 at 11:44 AM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> Paul Schrum wrote
>> > I started off trying to build it in a directory under my home directory
>> > using the instructions here
>> > <https://grasswiki.osgeo.org/wiki/Compile_and_Install_
>> Ubuntu#Dependencies>,
>> > but I could not get it to build.  The only part of those instructions
>> that
>> > I was not following were the path.  So I started using the paths
>> indicated
>> > in those instructions and then it would build.  That is why my copy of
>> the
>> > source is where it is.
>> > Based on yall's comments, I now think it was something other than the
>> path
>> > where I was storing the source code, but I have no idea what.
>> please post here your steps and error (?)/warning(?) messages of
>> compiling.
>> best regards
>> Helmut
>> View this message in context: http://osgeo-org.1560.x6.
>> nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-
>> tp5321487p5321504.html
>> Sent from the Grass - Dev mailing list archive at Nabble.com.
>> grass-dev mailing list
> grass-dev at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> grass-dev at .osgeo
no configure/compiling guru here on my side, googling
e.g. configure + "Cannot fork"
may show some issues with too many processes in your computer.
as your issue has changed from "Gaining write privileges to usr/local and
subdirectories" to some other, maybe changing the subject line of the thread
to get more devs involved.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321772.html
