[GRASS-dev] Windows - Bug in dll
Helmut Kudrnovsky hellik at web.de
Wed May 31 12:34:12 PDT 2017
>C:\GRASS_GIS\etc\python\grass\script\task.py", line 35, in
>¦ <module>
AFAIU you're using winGRASS standalone installer. Correct? Which Version?
winGRASS standalone bundles its own python version.
>¦     from xml.parsers import expat  # TODO: works for any Python?
>¦   File "C:\PYTHON26\LIB\xml\parsers\expat.py", line 4, in <module>
>¦     from pyexpat import *
>¦ ImportError: DLL load failed: %1 ist keine zulõssige Win32->Anwendung.
here it seems to point to an external python living in C:\PYTHON26.
Have you more python version installed on your Windows System?
these several python installations may interfere.
Could you rename C:\PYTHON26 to e.g. C:\xxxxPYTHON26 and try to restart
winGRASS and post the results here?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Windows-Bug-in-dll-tp5322538p5322540.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
