[GRASS-dev] [GRASS GIS] #3421: GEOS C API usage
GRASS GIS trac at osgeo.org
Sun Oct 8 13:35:20 PDT 2017
  Reporter:  Bas Couwenberg  |      Owner:  grass-dev@…
      Type:  defect          |     Status:  new
  Priority:  normal          |  Milestone:  7.2.3
 Component:  Default         |    Version:  7.2.2
Resolution:                  |   Keywords:
       CPU:  Unspecified     |   Platform:  Linux
Comment (by mmetz):
 Replying to [ticket:3421 Bas Couwenberg]:
 > GRASS is claimed to be using the GEOS C API instead of the unstable C++
 API according to:
 >  https://trac.osgeo.org/geos/wiki/Applications
 > `configure.in` checks for `geos_c.h`, but uses `geos-config --libs`
 instead of `geos-config --clibs` causing linking to `libgeos-<VERSION>.so`
 in addition to `libgeos_c.so`.
 > The attached patch updates the `geos-config` command to use `--clibs`.
 Thanks for the patch! Applied to trunk and relbr72 in r71544,5.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3421#comment:1>
