[GRASS-dev] Force --v flag whenever -l is instructed
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 9 04:05:45 PDT 2017
On 09/10/17 12:49, Nikos Alexandris wrote:
> * Nikos Alexandris <nik at nikosalexandris.net> [2017-10-09 12:18:29 +0200]:
>> * Moritz Lennert <moritz.lennert at ulb.ac.be> [2017-10-09 10:59:25 +0200]:
>>> On 07/10/17 10:39, Nikos Alexandris wrote:
>>>> In a grassy script, how can I force verbosity, i.e. --v whenever a flag
>>>> -l is instructed? Which will lead to
>>>> env['GRASS_VERBOSE'] = '3'
>>>> i.some.module input=some_input -l
>>>> should be identical to
>>>> i.some.module input=some_input -l --v
>>>> The following is, of course, not working:
>>>> #%rules
>>>> #% requires_all: -l,--v
>>>> #%end
>>> I don't think the -- flags are covered by the rules, so I think you
>>> have to do this in the code, i.e. something like this:
>>> if flags['l']:
>> Merci Moritz,
>> I tested already (before asking)
>> env = os.environ.copy()
>> if list_only:
>> but it does not work.
Yes, sorry, I just copied your line without thinking.
>> Aren't there other ways?
>> Thank you again, N
> I guess simply
> GRASS_VERBOSE=3
> export GRASS_VERBOSE
> It works!
Yes, but that's in a shell, not in Python, or ?
In Python, something like this should work IIRC:
import os
os.environ['GRASS_VERBOSE'] = '3'
Moritz
