[GRASS-dev] Which are the strds 'columns'?
Sören Gebbert soerengebbert at googlemail.com
Sat Oct 21 06:05:24 PDT 2017
the column option of:
`t.rast.list --help`
will show all columns that are available for time-stamped raster layer
SQL selection operations.
Best regards
Sören
2017-10-21 14:34 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> Shouldn't the following work?
> t.rast.univar lst where="mean > 10"
> sqlite3.OperationalError: no such column: mean
> 'min', 'max' and 'start_time' work.
> Where are the "columns"?
> Isn't the whole of what t.rast.univar -e reports supported?
> Thank you, Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
