[GRASS-dev] Invalid timestamp file for raster
Veronica Andreo veroandreo at gmail.com
Mon Oct 23 21:15:51 PDT 2017
Hi Nikos, thanks Sören :)
You can also use t.register for only one map if you want (t.register
maps=single_map start="2003-04-13 10:00:09"). In that way you timestamp
them as you import.
Then you create the strds (t.create) and pass the list of already
timestamped maps (t.register input=your_strds maps=list_of_maps).
Cheers,
Vero
El 24 oct. 2017 12:59 a.m., "Nikos Alexandris" <nik at nikosalexandris.net>
escribió:
> * Veronica Andreo <veroandreo at gmail.com> [2017-10-23 22:54:03 +0200]:
> Hi Nikos,
>> Have you tried with t.register?
>> You would need to set the start_time="2013-04-13 10:00:09.935626" plus an
>> increment="10 seconds". I have not tested, but it should work.
>> I think it's better than r.timestamp if you want to create time series,
>> even though it would be great to fix the bug in r.timestamp, anyway.
> I am r.timestamp-ing Landsat bands while importing them via a script and
> sourcing meta from MTL files. I noticed that in some cases, the time
> stamping did not work.
> Cheers, Nikos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171024/d6e71e16/attachment.html>
