[GRASS-dev] [release planning] GRASS GIS 7.2.2
Markus Metz
markus.metz.giswork at gmail.com
Thu Sep 7 12:59:23 PDT 2017
On Thu, Sep 7, 2017 at 5:04 PM, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 06/09/17 11:37, Martin Landa wrote:
>> Hi,
>> 2017-09-06 11:33 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
>>> None from me.
>> lets wait for next WinGRASS build, see r71469. Ma
> Colleagues just reported a bug in v.net.iso (but which seems to come from
the libraries). They will file a bug report, but here's the basics:
> v.net streets_wake points=schools_wake out=net op=connect thresh=500000
> v.net.iso net ccat=1-3 cost=500,5000,10000 out=isos
> Construction du graphique ...
> Enregistrement des arcs ...
> 100%
> Aplanir le graph ...
> Le graphique a été construit
> Number of centres: 3 (nlayer 2)
> Calculating costs from centre 1...
> ATTENTION: erreur de dglShortestPath: Bad Edge
> 100%
> Calculating costs from centre 2...
> 100%
> Calculating costs from centre 3...
> 100%
> v.category isos op=report
> Layer: 1
> type count min max
> point 0 0 0
> line 3 1 1
> boundary 0 0 0
> centroid 0 0 0
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 3 1 1
> MarkusM, could this be linked to
https://trac.osgeo.org/grass/changeset/70678/grass/branches/releasebranch_7_2/lib/vector/Vlib/net_analyze.c
This bug is caused by r71268 in relbr72, trying to support MS Windows
64bit. Fixed in r71477,8 (trunk, relbr72).
Markus M
> Running the same commands in trunk, I actually get a segfault in the
v.net.iso call, but I really do not have time to investigate this now.
> Not sure if this warrants holding back the release, but it does seem a
regression to 7.2.1.
> Moritz
> Département Géosciences, Environnement et Société
> Université Libre de Bruxelles
> Bureau: S.DB.6.138
> CP 130/03
> Av. F.D. Roosevelt 50
> 1050 Bruxelles
> Belgique
> tél. + 32 2 650.68.12 / 68.11 (secr.)
> fax + 32 2 650.68.30
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170907/a89f1598/attachment.html>
