[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Tue Sep 19 04:01:38 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by glynn):
Replying to [comment:33 mlennert]:
> Replying to [comment:32 glynn]:
> > The functions in grass.script should **never** return unicode. That
module reads the contents of files (which are sequences of bytes) and the
output from processes (again, sequences of bytes).
> Is this true for translated module messages as well ?
Yes. Anything which originates as a byte string (e.g. output from
commands, contents of files) should be kept as a byte string. Anything
which (for whatever reason) originates as a unicode string should be
encoded at the earliest opportunity.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:35>
