[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Vincent Bain bain at toraval.fr
Wed Sep 20 01:58:54 PDT 2017
Thank you Markus for your suggestion,
unfortunately I don't have any idea where to find the relevant piece of
code implied.
Vincent.
Le mercredi 20 septembre 2017 à 10:23 +0200, Markus Neteler a écrit :
> On Wed, Sep 20, 2017 at 9:06 AM, Vincent Bain <bain at toraval.fr> wrote:
> > Hi Helmut,
> > don't know if you finally found the reason of the warning message you
> > mentioned back in july. On a freshly built Debian stretch virtual
> > machine I have the same issue today :
> > ** (wxgui.py:5023): WARNING **: invalid source position for vertical
> > gradient
> > I guess it is not a fatal issue as GRASS seems to work nicely despite
> > this error.
> Searching the error in internet I found a similar one:
> ** (thunar:2530): WARNING **: invalid source position for vertical gradient
> https://github.com/lassekongo83/zuki-themes/issues/104
> Fix:
> https://github.com/lassekongo83/zuki-themes/commit/318efd3a83f6305414f58b9dca417072c16e5ef6
> Maybe something like this could be applied also here?
> Markus
