[GRASS-dev] [GRASS GIS] #3601: db.connect: default answers depend on current DB settings
GRASS GIS trac at osgeo.org
Fri Aug 3 14:18:25 PDT 2018
  Reporter:  mmetz     |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.4.2
 Component:  Database  |    Version:  svn-trunk
Resolution:            |   Keywords:  database, connection
       CPU:  All       |   Platform:  All
Comment (by mmetz):
 In [changeset:"73039" 73039]:
 #!CommitTicketReference repository="" revision="73039"
 db.connect: use GRASS default, not current parameters as default answer,
 fix setting from default and from user options (see #3601; backport trunk
 r72942)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3601#comment:3>
