[GRASS-dev] [GRASS GIS] #3537: Add functionalities –tmp-location and –no-clean
GRASS GIS trac at osgeo.org
Wed Aug 22 06:59:22 PDT 2018
  Reporter:  radeknovotny94  |      Owner:  grass-dev@…
      Type:  enhancement     |     Status:  closed
  Priority:  normal          |  Milestone:  7.6.0
 Component:  Startup         |    Version:  svn-trunk
Resolution:  fixed           |   Keywords:  tmp-location, no-clean, exec
       CPU:  All             |   Platform:  All
Comment (by Nikos Alexandris):
 Just some extra thoughts: perhaps the error message should *not* say
 anything but what actually happens: the file is not found.
 What are your thoughts in general? Even this very check, in case the file
 does exist, does not ensure that the file will be available. Right after
 the check anything can happen at the OS level.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3537#comment:9>
