[GRASS-dev] [GRASS GIS] #3448: v.buffer native failures
GRASS GIS trac at osgeo.org
Wed Aug 22 13:06:53 PDT 2018
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Vector       |    Version:  unspecified
Resolution:  wontfix      |   Keywords:  v.buffer v.parallel
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by mmetz):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 This is a long known issue and the reason why v.buffer uses GEOS
 buffering. GRASS native buffering will probably not be fixed because GEOS
 buffering is working, thus closing as won't fix.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3448#comment:4>
