[GRASS-dev] [GRASS GIS] #3466: v.to.db: check if column exists before running
GRASS GIS trac at osgeo.org
Wed Aug 22 13:19:56 PDT 2018
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Vector       |    Version:  svn-releasebranch74
Resolution:               |   Keywords:  v.to.db,column
       CPU:  All          |   Platform:  All
Changes (by mmetz):
 * type:  defect => enhancement
Comment:
 Changing to enhancement because the result is not incorrect if the
 column(s) don't exist. The requested check if the columns to be updated
 exist will not change the result.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3466#comment:3>
