[GRASS-dev] [GRASS GIS] #934: d.vect with z height colors uses a random polygon point for height - patch to fix attached
GRASS GIS trac at osgeo.org
Sat Aug 25 09:54:23 PDT 2018
to fix attached
  Reporter:  jarim        |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Display      |    Version:  svn-trunk
Resolution:               |   Keywords:  z height color zcolor
       CPU:  x86-32       |   Platform:  All
Comment (by martinl):
 In [changeset:"73181" 73181]:
 #!CommitTicketReference repository="" revision="73181"
 d.vect: explain z height for 3D lines/polygons, see #934
Ticket URL: <https://trac.osgeo.org/grass/ticket/934#comment:8>
