[GRASS-dev] r.in.gdal changes range of values for sentinel bands (?)
Veronica Andreo veroandreo at gmail.com
Mon Feb 5 04:05:28 PST 2018
Hi devs
I'm testing Martin's new add-on, r.sentinel.import. I created an UTM21S
location for my data and imported them with:
r.sentinel.import
input=Downloads/S2B_MSIL1C_20171212T134159_N0206_R124_T21KZP_20171212T201017.SAFE/GRANULE/L1C_T21KZP_A004011_20171212T134158/IMG_DATA/
The problem arose when I tried to use i.color.enhance to display an RGB: I
got blank screens, so I thought there must be something with the range of
values.
r.univar map=T21KZP_20171212T134159_B02 at PERMANENT
total null and non-null cells: 120560400
total null cells: 0
Of the non-null cells:
n: 120560400
minimum: 15
maximum: 17547
range: 17532
mean: 913.778
mean of absolute values: 913.778
standard deviation: 134.322
variance: 18042.4
variation coefficient: 14.6996 %
sum: 110165471238
that already seemed odd...
I checked the original band2 jp2 file... Values are different...
gdalinfo T21KZP_20171212T134159_B02.jp2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: T21KZP_20171212T134159_B02.jp2
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
  Min=602.000 Max=1576.000
  Minimum=602.000, Maximum=1576.000, Mean=916.799, StdDev=123.509
  Overviews: 5490x5490, 2745x2745, 1372x1372, 686x686
  Overviews: arbitrary
  Metadata:
    STATISTICS_MAXIMUM=1576
    STATISTICS_MEAN=916.7992
    STATISTICS_MINIMUM=602
    STATISTICS_STDDEV=123.50943477872
  Image Structure Metadata:
    COMPRESSION=JPEG2000
    NBITS=15
Just to check, I imported with r.in.gdal and I'm getting exactly the same
as with r.sentinel.import.
What am I doing wrong here? Why would r.in.gdal change values like that?
What else needs to be set? I don't remember to have this problem before and
it happens in all bands as far as I've checked.
Ah, I'm using trunk r72203
Thanks in advance for any help :)
Cheers,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180205/b25931a6/attachment.html>
