[GRASS-dev] r.in.gdal changes range of values for sentinel bands (?)
Veronica Andreo veroandreo at gmail.com
Mon Feb 5 11:54:52 PST 2018
Forgot the list, sorry...
Hi Markus,
here the output of gdalinfo -mm for the same band reported earlier:
gdalinfo -mm T21KZP_20171212T134159_B01.jp2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: T21KZP_20171212T134159_B01.jp2
Band 1 Block=192x192 Type=UInt16, ColorInterp=Gray
  Min=908.000 Max=1511.000   Computed Min/Max=934.000,6934.000
  Minimum=908.000, Maximum=1511.000, Mean=1138.806, StdDev=74.933
  Overviews: 915x915, 457x457, 228x228, 114x114
  Overviews: arbitrary
  Metadata:
    STATISTICS_MAXIMUM=1511
    STATISTICS_MEAN=1138.8064
    STATISTICS_MINIMUM=908
    STATISTICS_STDDEV=74.933459275813
  Image Structure Metadata:
    COMPRESSION=JPEG2000
    NBITS=15
still differs a lot from what I get after importing into GRASS.
System Info
GRASS version: 7.5.svn
GRASS SVN revision: r72203
Build date: 2018-01-01
Build platform: x86_64-pc-linux-gnu
GDAL: 2.1.3
PROJ.4: 4.9.3
GEOS: 3.6.1
SQLite: 3.20.1
Python: 2.7.14
wxPython: 3.0.2.0
Platform: Linux-4.14.14-200.fc26.x86_64-x86_64-with-fedora-26-Twenty_Six
best,
Vero
2018-02-05 19:49 GMT+01:00 Markus Metz <markus.metz.giswork at gmail.com>:
> On Mon, Feb 5, 2018 at 1:14 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > I tested also with 74 release branch... same result
> > 2018-02-05 13:05 GMT+01:00 Veronica Andreo <veroandreo at gmail.com>:
> >> Hi devs
> >> I'm testing Martin's new add-on, r.sentinel.import. I created an UTM21S
> location for my data and imported them with:
> >> r.sentinel.import input=Downloads/S2B_MSIL1C_201
> 71212T134159_N0206_R124_T21KZP_20171212T201017.SAFE/GRANULE/
> L1C_T21KZP_A004011_20171212T134158/IMG_DATA/
> >> The problem arose when I tried to use i.color.enhance to display an
> RGB: I got blank screens, so I thought there must be something with the
> range of values.
> >> r.univar map=T21KZP_20171212T134159_B02 at PERMANENT
> >> total null and non-null cells: 120560400
> >> total null cells: 0
> >> Of the non-null cells:
> >> n: 120560400
> >> minimum: 15
> >> maximum: 17547
> >> range: 17532
> >> mean: 913.778
> >> mean of absolute values: 913.778
> >> standard deviation: 134.322
> >> variance: 18042.4
> >> variation coefficient: 14.6996 %
> >> sum: 110165471238
> >> that already seemed odd...
> >> I checked the original band2 jp2 file... Values are different...
> >> gdalinfo T21KZP_20171212T134159_B02.jp2
> >> Files: T21KZP_20171212T134159_B02.jp2
> >> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
> >>   Min=602.000 Max=1576.000
> >>   Minimum=602.000, Maximum=1576.000, Mean=916.799, StdDev=123.509
> >>   Overviews: 5490x5490, 2745x2745, 1372x1372, 686x686
> >>   Metadata:
> >>     STATISTICS_MAXIMUM=1576
> >>     STATISTICS_MEAN=916.7992
> >>     STATISTICS_MINIMUM=602
> >>     STATISTICS_STDDEV=123.50943477872
> >>     NBITS=15
> Can you try again with gdalinfo -mm? This forces computation of the actual
> min/max values, which can differ from what is stored in the metadata (an
> approximation).
> There can also be something wrong with i.color.enhance
> Markus M
> >> Just to check, I imported with r.in.gdal and I'm getting exactly the
> same as with r.sentinel.import.
> >> What am I doing wrong here? Why would r.in.gdal change values like
> that? What else needs to be set? I don't remember to have this problem
> before and it happens in all bands as far as I've checked.
> >> Ah, I'm using trunk r72203
> >> Thanks in advance for any help :)
> >> Cheers,
> >> Vero
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180205/2fe7fdca/attachment.html>
