[GRASS-dev] Issue with double conditional in r.mapcalc (WinGRASS) and real life test of the aconda 7.5dev on Mac
Helmut Kudrnovsky hellik at web.de
Tue Feb 20 04:37:31 PST 2018
>We had a mix of installations on Windows:
>1 - QGIS standalone with GRASS7.2.2. (GRASS could also be run standalone it
seems)
>2 - WinGRASS 7.4.0. mostly direct install, but maybe some from OSGEO4W too.
>3 - WinGRASS7.5svn nightly
there shouldn't be much difference in behaviour
>We tried to use the command prompt to enter the scripts, but it made
trouble so we tried on the wxGUI >Console, and we found it worked mostly,
until we started entering more complex if statements. But that >was after we
had to remove quotes to enter the r.mapcalc script successfully anyway.
tested here now with
GRASS version: 7.4.0
GRASS SVN revision: r72154
Build date: 2018-01-27
Build platform: x86_64-w64-mingw32
and GRASS 7.5.svn dailys
r.mapcalc expression="s_sl = if( rbstreams500 at yann == 1, if( slope at PERMANENT
<= 5,  2, 5 ), 0 )"
*winGRASS windows console
C:\>r.mapcalc expression="s_sl = if( rbstreams500 at yann == 1, if(
slope at PERMANENT <= 5,  2, 5 ), 0 )"
 100%
*wxGUI console:
r.mapcalc expression=s_sl = if( rbstreams500 at yann == 1, if( slope at PERMANENT
<= 5,  2, 5 ), 0 )
(Tue Feb 20 13:30:06 2018) Command finished (0 sec)
both in winGRASS windows console and wxGUI console, the r.mapcalc with
double conditional works here.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
