[GRASS-dev] [GRASS GIS] #3504: v.rast.stats: add "mode" and "diversity" to methods
GRASS GIS trac at osgeo.org
Sun Feb 25 17:43:32 PST 2018
 Reporter:  veroandreo    |      Owner:  grass-dev@…
     Type:  enhancement   |     Status:  new
 Priority:  normal        |  Milestone:  7.4.1
Component:  Vector        |    Version:  svn-trunk
 Keywords:  v.rast.stats  |        CPU:  Unspecified
 Platform:  Unspecified   |
 Currently, if one needs to extract mode and diversity statistics from a
 Land Cover raster map for polygons in a vector map, polygons need to be
 converted to raster format, then use G7:r.statistics (which seems to be
 the only module providing mode) and then query r.statistics' output
 raster(s) with v.rast.stats again. If v.rast.stats would provide these
 basic info, the workflow would be very much simplified.
 Would it be possible to add mode and diversity to the methods available in
 G7:v.rast.stats?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3504>
