[GRASS-dev] Untangling geoPAT installation when updating GRASS version
Pierre Roudier pierre.roudier at gmail.com
Sun Feb 25 19:40:22 PST 2018
Hey Dylan,
Yes, these were installed using the grass-dev package in the UnbuntuGIS
repo,
Cheers,
P
On 24 February 2018 at 12:22, Dylan Beaudette <dylan.beaudette at gmail.com>
wrote:
> How about your GRASS "development" files: installed via package
> manager? Same version as the binaries?
> D
> On Fri, Feb 23, 2018 at 1:10 PM, Pierre Roudier
> <pierre.roudier at gmail.com> wrote:
> > Thanks Dylan,
> > I did install using `sudo sh install.sh grass72` -- then `sudo sh
> install.sh
> > grass74` after my Grass version got updated to 7.4
> > Cheers,
> > P
> > On 23 February 2018 at 18:41, Dylan Beaudette <dylan.beaudette at gmail.com
> > wrote:
> >> Howdy Pierre!
> >> In my experience, the GeoPat modules need to know where several things
> >> are located, including (I think) parts of the GRASS source code. Have
> >> a look through the install.sh code:
> >> http://sil.uc.edu/gitlist/geoPAT/blob/stable/install.sh
> >> I was able to get these modules up and running by invoking install.sh
> like
> >> this:
> >> sh install.sh grass75
> >> ... where "grass75" is the binary compiled from grass_trunk. The
> >> install.sh code seemed to find the source code it needed and worked
> >> without issue.
> >> How did you install / upgrade the Geopat modules? Could it be that
> >> install.sh is "finding" the old source code / headers? Is there a
> >> package for both GRASS binaries and development files?
> >> Dylan
> >> On Thu, Feb 22, 2018 at 7:28 PM, Pierre Roudier
> >> > Hi,
> >> > I've been compiling the geoPAT extensions for GRASS from
> >> > At the time I was running GRASS 7.2.2 installed from the Ubuntu GIS
> >> > repository, but since this repo updated to GRASS 7.4, I have the
> >> > following
> >> > issue:
> >> > GRASS 7.4.0 (modis_lst_2015):~ > p.sig.polygons --help
> >> > ERROR: Module built against version $Revision: 70617 $ but trying to
> use
> >> >        version $Revision: 70829 $. You need to rebuild GRASS GIS or
> >> >        untangle multiple installations.
> >> > [Raster MASK present]
> >> > Any pointers about how to resolve the version tangling? I've tried
> >> > recompiling geoPAT, but that didn't work.
> >> > Cheers,
> >> > Pierre
> >> > _______________________________________________
> >> > grass-dev mailing list
> >> > grass-dev at lists.osgeo.org
> >> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180226/3b4694ae/attachment.html>
