[GRASS-dev] OSGeo Login required to get code
Vaclav Petras wenzeslaus at gmail.com
Sun Feb 25 20:16:27 PST 2018
it seems that there is some issue with authentication for Subversion. When
I try to download source code using `svn checkout` I get "Authentication
realm: <https://svn.osgeo.org:443> OSGeo Login". This was observed on two
computers with Ubuntu and I can reproduce that in Docker:
docker run -it --rm ubuntu
Using commands:
apt update
apt install subversion
svn checkout https://svn.osgeo.org/grass/grass/trunk
Getting this output (accepting certificate at the beginning and pressing
enter at the end):
A    trunk/lib/raster3d/region.c
A    trunk/lib/raster3d/rle.c
A    trunk/lib/raster3d/changetype.c
A    trunk/lib/raster3d/getblock.c
A    trunk/lib/raster3d/test/test_coordinate_transform.c
A    trunk/lib/raster3d/error.c
A    trunk/lib/raster3d/range.c
A    trunk/lib/raster3d/test/test_raster3d_lib.h
Authentication realm: <https://svn.osgeo.org:443> OSGeo Login
Password for 'root':
Username:
Password for '':
Username:
Password for '':
svn: E215004: No more credentials or we tried too many times.
Authentication failed
Expected result is of course checkout without the login prompt which
usually comes at the (first) commit.
Is this problem with the client or the server?
Thanks,
Vashek
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180225/3e5cc88d/attachment.html>
