[GRASS-dev] [GRASS GIS] #3193: r.out.gdal: add AUTHORITY node to the srs info of the exported raster
GRASS GIS trac at osgeo.org
Fri Jan 26 07:37:36 PST 2018
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  major        |  Milestone:  7.4.1
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.out.gdal,r.external.out
       CPU:  All          |   Platform:  All
Comment (by mmetz):
 Replying to [comment:12 hellik]:
 > Replying to [comment:10 mmetz]:
 > > Replying to [comment:9 hellik]:
 > > > Replying to [comment:6 mmetz]:
 > > > > Replying to [comment:5 martinl]:
 > > > > > This functionality was recently implemented in trunk, right?
 Reference is missing here.
 > > > > It was implemented by martinl with r71303
 > > > tested with the example above:
 > > > AUTHORITY["EPSG","31255"]
 > > > seems to be still missing
 > > The functions were implemented in r71303. An EPSG code was only
 exported with v.out.ogr. As of trunk r72160, an existing EPSG code is
 exported with r.external.out, r.out.gdal, v.external.out, v.out.ogr.
 > Backport candidat for 7.4.1?
 It's a new feature, and EPSG codes should not be required in order to
 support custom coordinate reference systems.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:13>
