[GRASS-dev] [GRASS GIS] #3487: vector digitizer unstable
GRASS GIS trac at osgeo.org
Wed Jan 31 12:34:33 PST 2018
 Reporter:  cmbarton   |      Owner:  grass-dev@…
     Type:  defect     |     Status:  new
 Priority:  normal     |  Milestone:
Component:  wxGUI      |    Version:  7.2.2
 Keywords:  digitizer  |        CPU:  OSX/Intel
 Platform:  MacOSX     |
 The vector digitizer is very unstable. Sometimes I got it to make a new
 map or edit an existing one, but other times this caused the GUI to crash.
 When it did work, I was unable to close out the vector digitizer and have
 the menubar deleted. This, in turn made it impossible to quit the GUI by
 normal means.
 The error (pasted below) is a python segmentation fault: 11 error. This is
 the same error that crashes the GUI when launching i.gui.iclass (ticket
 https://trac.osgeo.org/grass/ticket/34722). Perhaps it has the same
 underlying cause.
 This error happens with new Mac binaries that are full 64bit, using the
 current stable wxPython 3.0.2, and Python 2.7.14.
 It is a problem with both GRASS 7.2.2 and GRASS 7.4 svn
Ticket URL: <https://trac.osgeo.org/grass/ticket/3487>
