[GRASS-dev] [GRASS GIS] #3602: Quick Database Switcher
GRASS GIS trac at osgeo.org
Sun Jul 8 21:25:01 PDT 2018
  Reporter:  pshapley     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Database     |    Version:  7.4.0
Resolution:               |   Keywords:
       CPU:  x86-64       |   Platform:  All
Comment (by mlennert):
 Markus has answered and solved the specific schema + group issues, but
 from the OP it sounds as if one needs to change db.connect settings for
 the use of v.out.postgis. AFAICT, this is not the case: there is no need
 to mess with db.connect to use v.out.postgis. If this were the case, I
 would consider this as a bug, as these settings should only determine
 default attribute backend settings in a mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3602#comment:2>
