[GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X Error BadValue integer parameter out of range for operation
GRASS GIS trac at osgeo.org
Tue Jul 10 17:16:50 PDT 2018
operation
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  closed
  Priority:  normal      |  Milestone:  7.2.4
 Component:  LibOpenGL   |    Version:  svn-trunk
Resolution:  fixed       |   Keywords:  m.nviz.image, NVIZ, 3D, GLX,
                         |  X_GLXCreateContext, g.gui.animation
       CPU:  x86-64      |   Platform:  Linux
Comment (by wenzeslaus):
 Replying to [comment:31 hcho]:
 > Replying to [comment:30 wenzeslaus]:
 > > Would you mind creating an automated test? (Perhaps testing at least
 dimensions of created PPM.)
 > How does an automated test work?
 You write a Python class using `grass.gunittest` package in the best case
 (and a shell script in the worst case). See documentation here and let me
 know if you are missing some info there:
 https://grass.osgeo.org/grass74/manuals/libpython/gunittest_testing.html
 Here is an example, see the directory called `testsuite`:
 source:grass/trunk/raster/r.mapcalc
 > Is it automatically invoked by make?
 No, something like `make test` is still to be implemented, but it should
 be fairly straightforward to do so.
 > Different modules have different folder names for test scripts.
 Yes, there are some legacy tests (or tests which can't be automated) in
 directories with different names (or not in a subdirectory). The name
 which is picked by the automated tests is `testsuite`.
 If everything is done right, the tests will appear every day at:
 http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:33>
