[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Sat Jul 21 12:56:31 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hcho):
 Replying to [comment:77 hellik]:
 > Replying to [comment:76 hcho]:
 > > Please test r72997 on Windows.
 > tested with
 > GRASS version: 7.5.svn
 > GRASS SVN revision: r72999
 > Build date: 2018-07-20
 > Build platform: x86_64-w64-mingw32
 > GDAL: 2.2.4
 > PROJ.4: 4.9.3
 > GEOS: 3.5.0
 > SQLite: 3.17.0
 > Python: 2.7.14
 > wxPython: 2.8.12.1
 > Platform: Windows-10-10.0.17134 (OSGeo4W)
 > C:\>m.nviz.image elevation_map=elevation output=D:\temp\mnviz\elev
 perspective=15
 > Loading raster map <elevation at PERMANENT>...
 >  100%
 >  100%
 > Translating colors from raster map <elevation at PERMANENT>...
 >  100%
 > m.nviz.image complete. File <D:\temp\mnviz\elev.ppm> created.
 perspective=15 format=tif
 >  100%
 >  100%
 >  100%
 > m.nviz.image complete. File <D:\temp\mnviz\elev.tif> created.
 > seems to work now; ppm and tif of winGRASS added
 Good. Now it's the macOS only that doesn't work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:78>
