[GRASS-dev] [GRASS GIS] #3607: Removing map layer crashes wxGUI
GRASS GIS trac at osgeo.org
Thu Jul 26 13:27:04 PDT 2018
 Reporter:  cmbarton                     |      Owner:  grass-dev@…
     Type:  defect                       |     Status:  new
 Priority:  normal                       |  Milestone:
Component:  wxGUI                        |    Version:  7.4.0
 Keywords:  remove layer, layer manager  |        CPU:  OSX/Intel
 Platform:  MacOSX                       |
 If you try to remove a raster or vector map from the layer manager, using
 the "remove" option in the popup list launched by the button on the right
 side of the layer, it will crash the entire GUI with the following error:
 /Applications/GRASS-7.5.app/Contents/Resources/bin/pythonw: line 3: 25590
 Segmentation fault: 11
 /Applications/GRASS-7.5.app/Contents/Resources/python.app/Contents/MacOS/python
 This error and behavior is similar to those reported in #3472 and #3487.
 This was reported to me for v. 7.4.0 but also occurs in the most recent
 trunk (r73007)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3607>
