[GRASS-dev] Testing the new ZSTD raster compression - was: Re: GRASS GIS raster files: LZW compression?
Nikos Alexandris nik at nikosalexandris.net
Fri Jun 8 23:26:10 PDT 2018
* Markus Neteler <neteler at osgeo.org> [2017-12-06 10:41:19 +0100]:
>Hi,
>(subject renamed for clarity, original thread:
>part 1:
>https://lists.osgeo.org/pipermail/grass-dev/2017-October/thread.html#86395
>part 2:
>https://lists.osgeo.org/pipermail/grass-dev/2017-December/086738.html
>Welcome to GRASS GIS 7.5.svn (r71892)
>GRASS 7.5.svn (latlong):~ >
>export GRASS_COMPRESSOR=ZSTD
I am building a docker image, based on trunk, for which I need to ensure
that ZSTD is the default compressor.
What is the way to pre-set this at the configuration step, before
compiling, so as to avoid to take care about it later on by setting
GRASS_COMPRESSOR?
Thanks for any kind of comments, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180609/aeb8bac5/attachment.sig>
